Laminar bubble separation
Old   July 24, 2008, 15:56
Default Laminar bubble separation
Gilles
Hi everybody,
I am actually simulating the flow over a 3d wing using the transition model in CFX. My Y+ at the wall are less than 1 except at the near leading edge. I found a laminar separation bubble at 0 angle of attack at about 60% of the chord on the succion side. Could this be possible ??? Furthermore, on the pressure side, the transition occurs earlier as in the succion side. I think that this could be a numerical error. Has someone any idea ?
Thanks ! That would be very helpful !
Gilles
Old   July 24, 2008, 21:57
Default Re: Laminar bubble separation
Looks like you read my previous posting on laminar separation bubbles.
Possible at 60% chord? Yes.
Transition earlier on pressure side than suction side? Yes. If you have an asymmetric airfoil and you are running it at zero lift then it is likely the pressure side transition will be earlier.
Looks like you need to read some textbooks on airfoil design theory. Time to visit the library.
Separation bubble, hypersonic compression corner ben akih CFX 3 December 10, 2006 16:33
Laminar separation bubble Axilleas Tsompanos FLUENT 5 August 6, 2004 12:24
Laminar boundary separation yongsheng Fidelity CFD 2 March 26, 2003 16:04
V2F model and laminar separation Romuald Main CFD Forum 1 February 17, 2003 04:05
Laminar bubble separation Daniel Bruno FLUENT 0 May 10, 2001 23:11
