Hexa ICEM CFD
Like Tree1Likes
  • 1 Post By Charles
Old   July 24, 2008, 04:09
Default Hexa ICEM CFD
Amit
I am trying to generate mesh using Hexa option of ICEM CFD but getting negative determinant for many cells and also negative volumes for several cells. How can i correct this?
Old   July 24, 2008, 04:19
Default Re: Hexa ICEM CFD
Igor-a
Hi, try to change maximal size of element in problem surface also you can modify your bloking (if negative volumes is a result of so small minimal angles)
Old   July 24, 2008, 07:18
Rogerio Fernandes Brito
If u have several circle curves, u must use o-grid mesh, to avoid bad angles or so small angles. Remake your block, so! Tell us about your geometry. We´re very interesting to know it!
Old   July 28, 2008, 18:48
Charles
Step through your pre-mesh with scan planes, that should show where it is folding. Also, if you have created a block from vertices, you may have an inverted block, and will need to re-orient the IJK indices.
Far likes this.
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 16:14
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 03:41
ICEM CFD (Hexa) - > Phoenics James Date Phoenics 2 September 2, 2004 15:18
ICEM CFD Modules Boris FLUENT 1 March 12, 2004 14:37
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
