Sudden Solution Jump Near a Specific Mass Flow in CFX Centrifugal Compressor Simulati
Like Tree1Likes
Old   December 4, 2025, 06:31
OK, so if we suspect the SST model is inadequate then you should move to models like SAS and DES. You don't have to develop these models yourself, they are included in CFX (but they are not available to some entry level ANSYS licenses). If you decide to use these models you don't simply turn the model on and they work - they have implications on meshing, boundary conditions, making the model transient and so on.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   December 4, 2025, 11:17
Opaque will become famous soon enough
Originally Posted by LiuYD View Post
Thank you for the explanation. I have already tried this in CFX-Pre, and unfortunately, in my case I cannot use "exit corrected mass flow". Because my working fluid is an organic vapor, I handle the fluid properties by importing an RGP table. It seems that once the RGP table is used, the option for “exit corrected mass flow” disappears from the outlet boundary condition.
When I switch the working fluid to the built-in air property in CFX, the “exit corrected mass flow” option becomes available.
So, may I ask if you know any method that would allow me to use "exit corrected mass flow" while still using an RGP table for the fluid properties?
Set it as Air ideal gas, set the Exit Corrected Mass Flow option, reset back to your material, ignore the warning/error, write the definition file and see if it works.
Opaque is offline   Reply With Quote
Old   December 7, 2025, 02:41
LYD
LiuYD is on a distinguished road
hi Opaque
The method you suggested works — the calculation can be performed. Using exit corrected mass flow also shifts the location of the sudden jump, but the discontinuity still exists. I have shown the results in the figure below.
In addition, I used the same mesh and boundary conditions in both CFX and Numeca (another CFD solver commonly used for turbomachinery). The results are shown as well. Based on this comparison, we can basically rule out any design issue with the impeller itself. The appearance of the sudden jump is most likely caused by some unexpected numerical behavior in CFX, which leads to a non-physical solution branch.
LiuYD is offline   Reply With Quote
Old   December 7, 2025, 02:58
LYD
Yes, if we use SAS or DES, we will also need to investigate whether specific software settings might influence the results. Since I have been using the SST model and have already obtained some results, I would prefer to solve the issue within the SST if possible — including enabling the reattachment modification and high-lift modification, which I hope will help. Of course, if these still do not work, I will then consider using more advanced turbulence models.
Old   December 7, 2025, 06:05
And just checking - are you completely sure that this simulation is fully converged and the mesh is fine enough? What happens if you use tighter convergence or a finer mesh?
Old   December 8, 2025, 13:41
hi Opaque
Would you mind running the BSL model instead of SST? Have not had a chance to digest your previous convergence plots.
Exit Corrected Mass Flow Rate Mesh Sensitivity Study s__s__s CFX 4 July 20, 2016 12:46
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Split Mass Flow Rate in ANSYS CFX ashtonJ CFX 2 July 9, 2014 04:08
CFX mass flow boundary condition Michele Cagna CFX 3 February 22, 2007 16:52
