[Sponsors] | |||||
Questions About Mixing Plane Interface and Averaging |
Rep Power: 4 ![]() |
Hello, everyone.
In the CFX mixing plane interface, you set up two sides of the interface. After running a simulation, I've observed that these faces do not show the same values—for example, the velocity on one side differs from that on the other. I would like to understand why this happens. My second question relates to the CFX Solver Modeling Guide, which states regarding the mixing plane (Stage) model: "the Stage model performs a circumferential averaging of the fluxes through bands on the interface." Based on this, I expected each circumferential band to have a constant value. However, after simulation, this does not appear to be the case—contour plots of the interface still show gradients in both the circumferential and radial directions |
#2 | |
Rep Power: 34 ![]() |
"the Stage model performs a circumferential averaging of the fluxes through bands on the interface." which value should be uniform? (constant is about time not space)
#3 | |
I've found the problem it is said that fluxes are conserved and averaged circumferentially not the points data like velocities. But I didn't understand
| Tags |
| circumferential averagin, mixing plane, stage |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
| Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
| Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
| An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
| RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
