Question about hydrostatic pressure and gravity(buoyancy) term in CFX
Like Tree1Likes
  • 1 Post By Opaque
Old   December 18, 2025, 16:02
Default Question about hydrostatic pressure and gravity(buoyancy) term in CFX
smhk is on a distinguished road
I have some questions about how (hydrostatic) pressure is calculated in Ansys CFX.
In Ansys CFX theory guide momentum equation is written without the gravitational term (but there is a source term). I can activate buoyancy in domain settings but I'm not sure how that works.
  • Why we don't always turn gravity term on (like what it is in Navier-Stokes equation)?
  • Is the buoyancy model work only for multi-phase flows, buoyancy driven flows or you can use it for every other simulation like a Kaplan turbine or a hydrostatic case?
  • Do I need to activate buoyancy model in solving a water turbine model?(I know by using mass flow rate I somehow apply the effect of gravitational driving force for the turbine but I'm not sure shall I use buoyancy or not).
I also tried a simple case. I got these results which are weird to me.
Here is a simple 1m*1m*3m channel and blue arrows show mass flow at the inlet:
In the first experiment I didn't activate buoyancy. The relative pressure is symmetric. you can't see the hydrostatic pressure in relative pressure contour. it's symmetric:
The absolute pressure is also symmetric with no difference on any axis:
I wanted to see how buoyancy model works with this case so I activated buoyancy model in the domain setting:
when buoyancy reference temperature is the same as fluid reference temperature (in materials), I get this results for relative pressure and absolute pressure respectively:
you can't see the hydrostatic pressure in the relative pressure:
But in absolute pressure, hydrostatic pressure share is obvious the difference in pressure along Y axis must be about 10000Pa (g=10 m/s^2 & rho=1000 kg/m^3)
when buoyancy reference temperature is different from fluid reference temperature , I get this results for relative pressure and absolute pressure respectively:
In relative pressure contour there is pressure gradient in along Y but it's not 10000Pa it's only about 700Pa
but in absolute pressure contours, hydrostatic pressure seems correct and it's difference is about 10000Pa
why this happens?
Thank you
smhk is offline   Reply With Quote
Old   December 18, 2025, 17:04
Opaque will become famous soon enough
why this happens?
Thank you
Absolute Pressure = (Pressure + Reference Pressure) + Reference Density * gravity * (g dot local_position vector - local reference position)
Absolute pressure gradient = pressure gradient + Reference density * gravity * gradient *( g dot local position - local reference position)
Hope that helps
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Old   December 19, 2025, 06:28
Thank you for replying.
Absolute Pressure = Pressure + density * gravity * (g dot local_position vector - local reference position)
Is this the case when I use buoyancy model?
Why when I change the reference temperature (in buoyancy model) to some value other than temperature in my material properties the relative pressure becomes incorrect.
When Should I active buoyancy model?
Old   December 19, 2025, 09:51
That was the simplified version (which I updated to match the documentation)
For compressible, multiphase flow, the full buoyancy model is used. That is, the "(Density - Reference Density) * gravity is evaluated directly.
Have you read the documentation? Both sections: Theory Guide, and Solver Modeling Guide
smhk likes this.
buoyancy, cfx, gravity, hydrostatic pressure
