aspect ratio?
Old   August 19, 2008, 21:55
Default aspect ratio?
wan
Hi all,
i'm still confuse on aspect ratio defination. In few publised papers define the aspect ratio as (Height/width) but in other paper used hydraulic (diameter/channel lenght). So which one is the correct one?
thank you for you time.
Old   August 20, 2008, 02:02
Default Re: aspect ratio?
You can define it to be whatever is relevant to your situation. As you have noticed, when a paper talks about aspect ratio you have to be careful to understand exactly how they have defined it as it varies between authors.
Old   August 20, 2008, 02:50
wan
thank you Glenn
viel spass
Old   August 20, 2008, 08:18
Rogerio Fernandes Brito
I used to use Height/width or (H/L).
Take a look yourself:
http://200.131.186.194/phl/pdf/0029662.pdf
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
aspect ratio vs. y+ hammam CFX 3 August 6, 2007 10:41
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 12:01
does aspect ratio affect analysis mahesh Main CFD Forum 2 October 10, 2005 09:12
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 02:37
