does it follows mass, momentum, energy conservatin |
August 31, 2008, 03:31 |
how can we check, that the domain for which we make calculation, is following all conservation laws???
thank you. |
August 31, 2008, 21:52 |
Re: does it follows mass, momentum, energy conserv
Looks at the mass, momentum, energy imbalances. There will also be imbalances for additional variables, volume/mass fraction etc. Glenn Horrocks |
September 1, 2008, 01:08 |
Thanks Glenn:
would you please tell me; can we get a report of how much mass is flowing at a perticular time, as we get in the fluent. if it option is there than tell me how? |
September 1, 2008, 19:13 |
Yes, that is easy. Set up a monitor point under the output settings with an expression something like massFlow()@BoundaryName. Have a look in the CFX Reference manual in the section titled CEL Expression language for more detail on CEL. Glenn Horrocks |
September 2, 2008, 16:10 |
Actually, flows are already written to the mon file (which the Solver Manager reads from the run directory to make plots). Just create a new plot in the Solver Manager and pick the appropriate boundary region under the FLOWS section.
-CycLone |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
FEM fortran codes for coupled mass momentum energy | Amit | Main CFD Forum | 1 | May 17, 2005 20:38 |
FEM Formulation of 2D mass, momentum and energy eq | Amit | Main CFD Forum | 13 | May 6, 2005 13:23 |
