August 26, 2008, 03:17 |
LES-Smagorinsky model
Dear everyone..
I am going to use LES-Smagorinsky model for multiphase simulation of stirred tank reactor using ANSYS CFX 11.0 version. when i do setup the physics, i am getting the all turbulence model in menu list except LES-Smagorinnsky model, i was wondering whether i have to do somethingelse for setup of LES simulation in the case of multiphase flows. and also i have enabled the beta version options regards CFDUSESIN |
August 26, 2008, 19:52 |
Re: LES-Smagorinsky model
I think you might need an advanced turbulence modelling license to access this. Also it might not be on the GUI, you may have to call it in CEL. Glenn Horrocks |
August 26, 2008, 19:53 |
Sorry, you need to call it in CCL. CEL is the expression language which is different. Glenn Horrocks |
August 27, 2008, 05:03 |
Dear Glenn..
Thanks for replying.. we are already having advanced turbulence modeling license. could you suggest me where i could get CCL for LES model. Is there any templates available for LES model. regards CFDUSERIN |
August 27, 2008, 18:58 |
Well, just to rule out a silly reason, LES only shows up when you set your simulation type to transient. Have you done that already?
August 28, 2008, 00:43 |
Dear brunoc..
Now i got it... Thanks lots... regards CFDUSERIN |
ansys fluent les model | bene | Main CFD Forum | 0 | June 7, 2011 10:45 |
LES model : smagorinsky | s-ammarlu | OpenFOAM | 0 | June 4, 2011 00:54 |
Bug in Dynamic 1Eq Eddy Viscosity LES Model Incompressible flow | harishg | OpenFOAM Bugs | 5 | December 2, 2008 18:18 |
Smagorinsky model | sylvain91 | OpenFOAM Running, Solving & CFD | 0 | June 22, 2006 06:29 |
Smagorinsky closure model for LES | Jimmy | FLUENT | 0 | December 18, 2002 04:33 |
