August 5, 2008, 11:49 |
ANSYS/CFX and Vista
Hello
Just wondering if anyone can help with the following. I am about to buy a new computer that will primarily be used for running Ansys CFX. Will Ansys work with Vista? Am I correct in saying that if you have 64-bit Vista then you also need 64-bit Ansys? Thanks in advance. S |
August 5, 2008, 12:00 |
Re: ANSYS/CFX and Vista
64-bit Vista then you also need 64-bit Ansys -> YES, but u can try to instal a cfx 32 bits
Will Ansys work with Vista? i donīt think so, īcause i use xp 64 bits. |
August 5, 2008, 12:11 |
Ok. Thanks for that. I'm still unclear however as to whether I will be able to use Ansys with Vista? What version do you use with XP 64-bit?
S |
August 5, 2008, 16:16 |
ANSYS CFX-v11.0 with Service Pack 1 (64 bits) for Windows XP of 64 bits too!
August 5, 2008, 20:23 |
ANSYS and CFX is fully supported in Windows Vista, in both 32 and 64 bit modes. You need V11 service pack 1. Glenn Horrocks |
August 11, 2008, 06:46 |
Is there any advantage running Vista 64bit (or XP 64bit) if ANSYS is 32bit?
Any comments are appreciated. |
August 11, 2008, 18:41 |
No advantage in putting ANSYS 32 bit on a 64 bit OS. But it is a simple matter of just installing the 64 bit version of ANSYS and you will be able to run bigger models that 64 bit allows. Glenn Horrocks |
August 12, 2008, 02:36 |
Glenn
Thanks for that. Presumably, the 64 bit version of ANSYS is provided by service pack 1? Thanks again. |
August 12, 2008, 22:31 |
#9 |
No, it is a separate installation.
Glenn Horrocks |
August 21, 2008, 17:19 |
#10 |
I downloaded the Ansys 11 x64 from the web but I haven't installed it coz the package seems to be incomplete. It needs a file from the Ansys 11.0 x64\program files\ANSYS Inc\V110\AISOL\DesignSpace\DSPages\Language directory and i don't know what it is. Could u help me? |
August 23, 2008, 15:43 |
#11 |
yes Ansys 32 bit will work on ur 64 bit vista and on 64 bit xp too but wont use full resources of ur system....
August 28, 2008, 10:11 |
#12 |
I was thinking about installing Ansys/CFX on my 64 bit Vista machine I just purchased. My question is, if I create the .def files for a simulation in this 64 bit system, will I be able to run them on a 32 bit solver (I'm only asking because I have access to a cluster of 6 quad core cpus which is running linux and is set up to run simulations by transferring the def files and running them on the cluster). So really, the question is, are 64bit ansys .def files compatible with 32 bit ansys solvers?
September 3, 2008, 10:54 |
#13 |
Hi Sam, I work with Vista and Inventor 2009 and Ansys WB and Ansys CFX. CFX mesh does NOT work on vista 64bit no support either. the solver, pre and post runs normal on vista 64bit
tips for runing Gambit without Exceed in Win Vista | Fabio Saltara | FLUENT | 9 | September 23, 2011 13:59 |
Vista Client - Linux Server Connectivity Issue | vismech | STAR-CCM+ | 2 | July 17, 2009 08:12 |
Fluent / Gambit on VISTA or XP ??? | Ralf Schmidt | FLUENT | 2 | February 25, 2009 21:35 |
vista, cfx 11 | alireza | CFX | 6 | February 25, 2008 09:19 |
Can workbench and cfx run correctly on vista? | Sandam | CFX | 1 | December 2, 2007 16:32 |
