[urgent] ICEM: from 2D to 3D using extrude
Old   September 27, 2008, 08:05
Default [urgent] ICEM: from 2D to 3D using extrude
Hao
I followed the ICEM tutorial: 2D pipe junction and define several blocks to mesh a 2D geometry. No surface was created. After converting pre-mesh to unstructured mesh, I used extrude to get one-element thickness in z direction. Then in the output Tab, I choose "ANSYS CFX" solver and write input file. However, when i tried to import the mesh (.cfx5) in CFX-Pre, always an error, saying that no mesh exists in the requested file. I has been stucked for several days. Would anyone please help me? Thanks a lot.
Old   September 27, 2008, 16:30
Default Re: [urgent] ICEM: from 2D to 3D using extrude
Zbynek
Hi, my first suggestion: Did you define the ICEMCFD as a file format in CFX-Pre/Mesh_Import dialog ?
second: Has you checked the mesh by ICEMCFD mesh checking?Is it without problems? Zbynek
Old   October 2, 2008, 06:17
rohit
did the mesh is error free when checked in icem with check mesh? and second point when you export in icem is it doing the export without any errors?
Old   March 11, 2010, 12:01
Joshua Counsil
Josh is on a distinguished road
I is hasing the same problem. Any help?
Josh is offline   Reply With Quote
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
[Gmsh] Cannot get the right mesh from gmsh JinBiao OpenFOAM Meshing & Mesh Conversion 2 August 31, 2010 04:51
Extrude mesh in ICEM CFD Susan CFX 2 November 5, 2007 17:10
EXTRUDE option in ICEM CFD Geometry Mohammad Faridul Alam CFX 4 October 25, 2007 17:47
How to extrude 2D Mesh in ICEM CFD? VSB CFX 7 December 27, 2006 11:58
