animation
Old   October 7, 2008, 09:17
Default animation
Sungho Yoon
I found that animation using CFX post is based on 24 frames per second.
Is there any way that I can control the number of frames per second? Say, 12 frames per second?
Regards, Sungho
Old   October 7, 2008, 09:45
Default Re: animation
rohit
Yes you can control the no. of frames by clicking "option" button and then in popup you can go in the advanced tab where you can change the no.of frames, but i could see that you can only increase the no.of frames
Old   October 7, 2008, 09:49
Federico
Hi Sungho,
To change the frame rate you must click on the 'options' tab which is located in the bottom right corner of the 'animation' window. Once the 'option' window opens click on 'advanced' and select the frame rate that you want. If you are performing a 'keyframe animation' you can also choose an animation speed in the 'options' tab.
Regards,
Federico
Old   October 7, 2008, 10:16
Sungho Yoon
Thank you very much.
Regards, Sungho
Creating animation through TUI wawa FLUENT 27 November 5, 2021 03:17
Cropping animation spatially smonsch ANSYS 0 September 3, 2009 14:09
Multiblock animation in Tecplot. Simon Tecplot 4 February 10, 2006 10:27
Animation query..newbie qn derick FLUENT 2 December 9, 2005 09:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 11:19
