October 15, 2008, 03:39 |
Modeling movement of compressor valve
i'm trying to model the movement of compressor valves by CEL with mesh deformation. I use one domain. The valve (see picture) is defined as boundary with specified displacement (CEL). I had no idea how to model the elements for the flow when the valve is openened, so I tried to keep it already open to the beginning of the simulation, and to "expand" the elements in the crack (beginning height 0.2 mm). (expanding factor 25. The beginning aspect ratio of the elements in the crack is 1:5, in the end 5:1) However the end is never reached, because the poor elements surrounding the crack get negative volumes (yet if the valve is opened 1 mm) and solution stops. My question is now, whether there exists a better way to model this problem ("creating elements ex nihilo") or how to realize it with the existing method. Thank You for your replies!!! http://img355.imageshack.us/my.php?image=01zd7.jpg http://img604.imageshack.us/content..../179/01zd7.jpg http://img100.imageshack.us/my.php?image=02iu4.jpg http://img604.imageshack.us/content....5892/02iu4.jpg http://img100.imageshack.us/my.php?image=03by8.jpg http://img604.imageshack.us/content..../953/03by8.jpg Last edited by wyldckat; September 3, 2015 at 17:12. Reason: disabled embedded images |
Display Modes | |
modeling movement of body in fluid | Hossein | FLUENT | 0 | November 18, 2008 05:33 |
modeling flag movement | Nader Rahbar | CFX | 2 | September 27, 2006 23:00 |
modeling flag movement with fluent | Nader Rahbar | FLUENT | 0 | September 22, 2006 14:37 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 12:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 15:49 |
