October 15, 2008, 04:51 |
block strategy in ICEM
Hi,I am generating mesh in ICEM. It's a room ventilation with several slots on the ceiling. After I blocked the model with 3D block, I only got the mesh on the whole surface including ceiling and inlet without recognizing the vertex of inlet at all. In this case, may I make another surface block except for the 3D block? Does it mean multi-block? I am going to use cfx to do the simulation. Thank you!
October 16, 2008, 04:20 |
Re: block strategy in ICEM
I found the way using split face. Thanks.
Display Modes | |
[ICEM] Multiple fluide zone in ICEM Hexa Block problem | ddqp | ANSYS Meshing & Geometry | 4 | October 9, 2013 10:57 |
[ICEM] Unstructured "all quad" mesh in ICEM Block Method | Zeppo | ANSYS Meshing & Geometry | 7 | November 20, 2012 15:58 |
Domain size icem cfd block mesh | erhan61 | ANSYS Meshing & Geometry | 1 | March 29, 2011 09:39 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
what is orient block in icem | suresh | CFX | 0 | April 13, 2007 10:33 |
