[CFX-Mesh] body selection
Old   October 15, 2008, 04:56
Default [CFX-Mesh] body selection
Schmutz
Good morning, I am a new CFD user, I do my diploma work about a aerodynamic simulation in a High Ingeneer School in Switzerland.
How I can select the body (for example the wing) in CFX-Mesh to refine a face mesh or add inflations ? If I draw the half, I can do that without problem, but when I draw the full model, I can't select it because it's in the containing box.
Thank you, I wait about your responses.
Old   October 17, 2008, 11:15
Default Re: [CFX-Mesh] body selection
John S.
Are you trying to edit in the Workbench mesher or in CFX-Mesh? If I understand correctly, CFX mesh used to be stand alone in WB10 but in WB11 it became a "method." You can specify CFX mesh method but still edit in CFX-Mesh. Right click on CFX-Method and select edit in CFX-mesh to bring up the CFX mesh interface. I think it'll be easier to work with the model that way.
John
How to make appear edge/line body (created in design modeler) in the meshing tool Rockda ANSYS Meshing & Geometry 6 June 8, 2016 23:10
6DOF with floating body bounce back. paka FLUENT 4 June 6, 2013 11:32
Imported ICEM mesh has additional body in the mesh Procyon CFX 1 January 27, 2011 16:21
Body in windtunnel - high preassure behind the body? Andyjoe OpenFOAM 4 February 16, 2010 10:57
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
