expert parameter
hi all CFX users, iŽd like to use an Expert Parameter to let the back up file not be over wroten. In the user manual the following sentence is wroten: "All of the parameters can be inserted using the command file editor and written back into the definition file before excuting the CFX-Solver".
I can write a txt file in editor and save in format *.txt. Can anyone tell me how can be read the txt file into the *.def file? thanx in advance Best regard |
Re: expert parameter
cfx5cmds -write -def <deffile> -text <textfile>
Sorry (gvd html codes)
cfx5cmds -write -def deffile -text textfile |
You can insert expert parameters directly in CFX-Pre as well. Just right click on the Solver folder and choose "Insert>Expert Parameter". Most of the parameters will appear in the GUI panel that comes up. If you need one that doesn't (i.e. an undocumented one), just add any of the ones shown to create the Expert Parameter object then right click on it and choose "Edit in Command Editor" to insert the parameter manually.
Note that backup files will only be deleted if you specify a regular interval (i.e. every 10 iterations) or an elapsed time interval (i.e. every half hour). If you specify a list of iterations (i.e. 5,10,20,30,...), these will be preserved. -CycLone |
