expert parameter
Like Tree2Likes
  • 2 Post By CycLone
Old   October 27, 2008, 04:30
Default expert parameter
sometimes1900
hi all CFX users, iŽd like to use an Expert Parameter to let the back up file not be over wroten. In the user manual the following sentence is wroten: "All of the parameters can be inserted using the command file editor and written back into the definition file before excuting the CFX-Solver".
I can write a txt file in editor and save in format *.txt. Can anyone tell me how can be read the txt file into the *.def file? thanx in advance
Best regard
Old   October 27, 2008, 05:44
Default Re: expert parameter
Bart
cfx5cmds -write -def <deffile> -text <textfile>
Old   October 27, 2008, 05:45
Bart
Sorry (gvd html codes)
cfx5cmds -write -def deffile -text textfile
Old   October 27, 2008, 11:41
CycLone
You can insert expert parameters directly in CFX-Pre as well. Just right click on the Solver folder and choose "Insert>Expert Parameter". Most of the parameters will appear in the GUI panel that comes up. If you need one that doesn't (i.e. an undocumented one), just add any of the ones shown to create the Expert Parameter object then right click on it and choose "Edit in Command Editor" to insert the parameter manually.
Note that backup files will only be deleted if you specify a regular interval (i.e. every 10 iterations) or an elapsed time interval (i.e. every half hour). If you specify a list of iterations (i.e. 5,10,20,30,...), these will be preserved.
-CycLone
Kummi and aero_head like this.
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
MAxium residual...confusion with expert parameter KK CFX 3 February 8, 2008 10:47
asking for a few expert parameter for rotarywing charles CFX 4 November 3, 2006 14:15
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 19:28
