reason for only surface in ICEM
Old   November 6, 2008, 06:12
Default reason for only surface in ICEM
jai
why in ICEM, we cannot create volume? why we here defining volume by closed only surfaces? while deleting surface, how can automatically delete the lines and points relate to that surface?
Old   November 6, 2008, 12:04
Default Re: reason for only surface in ICEM
Amod
All the pre-processing softwares are concerned only witht the topology and not the way volume are visualized. What you may be comparing is the way ICEM represents volume with CAD software such as Unigraphics or Pro-E. By definition, a volume is a geometric entity bound by surface. Hence, ICEM is correct!
In ICEM, all geometric entities are grouped i.e. point, lines, surfaces and volumes are grouped in default groups. You can delete lower order entities automatically. You may use "Rebuild Topology" option to get rid of unwanted points and lines.
Hope this explains your query!
Amod
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
Mesh only one surface in ICEM Daniel Edebro CFX 3 December 5, 2006 06:59
Single surface as a boundary in ICEM Andrew CFX 1 October 30, 2006 13:30
Normal - Helical Surface m. malik Main CFD Forum 3 February 3, 2006 12:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
