open channel flow with a layer of air
Old   November 14, 2008, 12:32
Default open channel flow with a layer of air
Naomi
I'm trying to model open channel flow with a layer of air on top but it is not working. Any idea on how to place the B.C.'s and set it up to show the waves on the water
thanks
Old   November 15, 2008, 06:34
Default Re: open channel flow with a layer of air
mitesh patel
hi there, for this kind of problem, first you have to define two domain one is for water part and second is for air part. in basic setting of domain, you should select air and water as a fluid and in water domain initialisation take water volume fraction as 1 and air volume fraction 0 and in air domain initialisation take air volume fraction as 1 and water volume fraction 0. and specify BC as usual way.
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 18:30
Open Channel Flow ElanMorin FLUENT 4 February 25, 2015 16:26
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
pressure outlet (open channel flow) Willem Brantegem FLUENT 2 April 4, 2007 02:40
open channel flow boundary conditions yan FLUENT 0 July 4, 2005 23:36
