November 11, 2008, 06:47 |
Contour plot with negative velocity
Just to let you know the solution of the riddle...I was using log scale...and of course the log scale can't use negative numbers... So, with linear scale and local values of the variables it works perfectly. Sorry about this stupid problem.
November 12, 2008, 15:42 |
Re: Contour plot with negative velocity
Hi J,
Thanks for the update. Don't feel stupid; we've all been there. It never occurred to me to ask whether it was linear or log (most users don't realize they can plot on a log scale). So I have to ask, were you also plotting on a log scale in Tecplot? -CycLone |
November 13, 2008, 03:48 |
Hi man! Nope, on tecplot I used a normal linear scale. But I want to check also the log scale...and see what Tecplot says to me...
November 13, 2008, 11:25 |
I'd be interested in what Tecplot does. The problem with the log plot is you can never get to zero in order to cross over from negative to positive. One solution would be to have a lower limit on the log scale, after which it switches from positive to negative.
You can emulate this in Post by creating a contour with two levels, one below zero and one above, creating user surfaces on each level, then creating a logarithmic contour on each side with inverted color ranges. -CycLone |
[OpenFOAM] basic question contour plot in paraview | Kate | ParaView | 7 | July 23, 2020 14:05 |
How to Contour plot for omega_z ?? | snehal | OpenFOAM | 3 | March 11, 2017 05:41 |
[OpenFOAM] Contour Plot with Paraview | jet | ParaView | 0 | August 26, 2010 10:30 |
contour plot help | jesse@uconn | FLUENT | 0 | February 15, 2010 19:05 |
Velocity plot | J | CFX | 5 | October 27, 2008 12:13 |
