interplote data from post file
Old   November 13, 2008, 12:11
Default interplote data from post file
Kishan Patel
hi there,
i am trying to simulate the pipe with fluid entering with high temp. and because of conductive material it will going to loss heat and becoming cool. for this first i simulate only fluid part. In next stage i want to simulate solid pipe part which is some conductive material. From the result file of fluid part i got the data of temperature at wall. this temperature data at wall, i have to give at inner surface of solid pipe in ansys pre. so how can i do that?
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
