maximum mesh expansion factor reg
Like Tree1Likes
  • 1 Post By Toralf
Old   November 19, 2008, 11:00
Default maximum mesh expansion factor reg
NVSD BABU
hi when i was meshing air volume with inflation, iam getting successful mesh, but in solver maximum expansion ratio showing 101.9 and i am unable to get the convergence. Can any body help me, how to reduce maximum mesh expansion factor and tell me and tell me how can i see the maximum expansion factor while doing the mesh.
Thanks
NVSD BABU
Old   November 20, 2008, 02:03
Default Re: maximum mesh expansion factor reg
Toralf
that's tricky and I am interested in same problem. I have reduced my expansion factor including proper prism layer design but never below factor 200 (turbo problem). next item: in ICEM you can check under "check mesh" --> quality --> volume expansion. the values are not the same in solver and ICEM.
Mfaizan likes this.
Old   November 20, 2008, 03:46
pratik mehta
hi, I think mesh expasion factor for complex geometries cannot be controlled in the given CFX range espically when you are doing a tet mesh+ prism layers.
Actually you need to check out in post where does this max value exist in your domain , and later try to see how to improve your surface mesh variation near by that region.
Personally thinking Mesh Exp for 100 or 200 it not a problem for convergence,,, what turbulence model are you using ,, try out the first order advection scheme for faster convergence
I hope this helps
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
reduce mesh expansion? memahfud CFX 0 June 12, 2009 21:42
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
