November 19, 2008, 15:38 |
suggestions for turbulence model
Hi, I am trying to get the details of boundary layer as much as I can, so I'd like to use Low-Reynold k-e turbulence model, but I cannot find it in CFX. Thank you.
Regards, Li |
November 20, 2008, 03:10 |
Re: suggestions for turbulence model
Hi Li,
you cannot find the list of turbulence models? double-click on any domain and choose a model from the pull-down menu in "fluid models". the model than is valid for all domains. good luck. |
November 20, 2008, 03:47 |
Hi Toralf,
Thank you for the post. I can find the list of turbulence models, but I cannot find low-Reynold k-e turbulence model. |
November 20, 2008, 04:16 |
Hi Li,
i have never heard about specific low-reynolds k-e model. you can find in solver modeling guide k-omega is recommended for low-reynolds numbers as well. in my list of turbulence gives no low-reynolds number k-epsilon model. maybe others can help. greetings |
November 20, 2008, 12:08 |
CFX uses automatic wall treatments in its turbulence modeling based on your grid y+. For resolving a boundary layer simulation I would probably use the SST model. If your grid has an adequate inflated boundary it will automatically employ a low Re wall treatment.
November 21, 2008, 04:44 |
Hi Toralf and John, thank you for the post. I ever tried SST model in room ventilation simulation, but the results is not in good agreement with the benchmark test data. I am sure the grid is good enough in the benchmark test simulation and I also checked the output file to see the converstation balance and it converged well . So that's why I worried to use SST model.
What I am doing now is to simulate a square wind tunnel to study the gas emission from the surface. I need to solve the boundary layer. I will try to use SST model and if you have any suggestions, please tell me. Thank you! Regards, Li |
Display Modes | |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 03:08 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 16:25 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 21:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 20:13 |
