not getting convergence
Old   November 21, 2008, 09:41
Default not getting convergence
NVSD BABU
HI
iam working on simple natural convection problem. i have taken a copper plate of 1250*80*5mm and placed vertically in a steel enclosure of size 1630*510*150 and 2mm steel thickness.steel enclosure opened at bottom and closed at top.
for analysis i have considered only copper plate and air inside the steel encloser,i have given inflation mesh to air,which is having around 105000 elements.i have given copper-air interfaces. I have given opening boundary condition to bottom portion of air and all other outer faces declared as adiabatic walls.my model's vertical direction is y , i have given density as -9.81 in Y direction.tarbulence model used is k-e.I have tried both idealgas and air at 25 degC.i have tried different time steps for air and copper.
Plese help me
Thanks a lot
NVSD BABU
Old   November 22, 2008, 06:19
Default Re: not getting convergence
NVSD BABU
hi plz find the geometry and give the comments that i have to follow
http://img153.imageshack.us/img153/4...mainlr5.th.png
Old   November 24, 2008, 11:35
pratik mehta
Could you please tell what kind of convergence issue are you facing, is your problem diverging or you simply not achieving the residual lower limit?.
thanks,,
Old   November 25, 2008, 00:14
NVSD BABU
thank you pratik
i have given convergence as 1e-4, v-momentum not getting converged, it is oscillating and all other u,w and p getting 1e-4 convergence,but they are also oscillating.
Thank you NVSD BABU
Old   November 25, 2008, 03:55
pratik mehta
Is it is high resolution scheme that you are running with or blend factor, kindly switch on the double precision tab as well, what is your global Y plus range and let me know more about the moniter points if at all you have
best of luck
Old   November 25, 2008, 07:08
NVSD BABU
Thanks pratik, i will try with double precision.
I have tried high resolution,upwind and blend factor1 schemes.
Maximum mesh expansion factor is 70.1
moniter point is temperature.
Thanks
Old   November 25, 2008, 07:22
NVSD BABU
hi prathik
global Y+ range is 0 to 3.412
Thanks
Old   November 25, 2008, 15:59
Pratik Mehta
Sounds all basic settings seems good, are you solving it steady state or unsteady state . Try running with smaller time steps . First use K epsilon model and first order trasient case. Let me know what happens then
Old   November 26, 2008, 04:04
NVSD BABU
thanks prathik
I am solving the problem as steady state.If i do in trasient state,please tell me how to take total duration and time steps. practically, to get convergence our model took 4hrs. do i give 4hrs as total duration.
Thanks
Old   November 26, 2008, 21:49
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Old   November 27, 2008, 08:36
  #11
pratik mehta
You need to find out the suitable timescale of your problem in way from the velocity lenght scale and the integral lenght scale , but usually it is so straight forward for complex geometries , in that case you can iterate your time scale factor starting from the time scale factor that CFX uses during the steady state calculation , we can get this number from the output file.
So run trasient with Kepsilon n first order ... i hope your fluid properties are reasonably quoted , anyways try out this and lets see what you get
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
