November 26, 2008, 03:52 |
icem script
Hello! I'd posted this some time ago. I've got 3 icem .rpl scripts to run my simple geometry creation, meshing and conversion to .cfx5 format. All 3 scripts run individually at the DOS prompt as well as in icem replay mode. If I load the commands into a .bat file only the first command is run. The window then closes. Has anyone encountered this before? Suggestions are requested and are welcome. Prad The commands are: echo ICEM Tetin "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_tin.rpl echo ICEM Mesh "C:\Prog..........icemcfd\win\bin\icemcfd.bat" -batch -script icemcfd_hex.rpl echo ICEM cfx5convertion "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_con.rpl
November 26, 2008, 05:36 |
Re: icem script
November 26, 2008, 07:19 |
Re: icem script
echo ICEM Mesh "C:\Prog..........icemcfd\win\bin\icemcfd.bat" -batch -script icemcfd_hex.rpl echo ICEM cfx5convertion "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_con.rpl There's really nothing more to it: the tin is a 2d square. The 2d planar blocking, edge definition and meshing is defined in the icemcfd_hex.rpl Conversion to .cfx5 format is in the last .rpl. Put all three in a test.bat and double click, only one line runs. |
November 26, 2008, 07:55 |
Re: icem script
Is this the code?
echo ICEM Tetin "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_tin.rpl echo ICEM Mesh "C:\Prog..........icemcfd\win\bin\icemcfd.bat" -batch -script icemcfd_hex.rpl echo ICEM cfx5convertion "C:\Prog...........icemcfd\win\bin\icemcfd.bat " -batch -script icemcfd_con.rpl |
December 16, 2008, 14:32 |
Re: icem script
I'm not sure the connection between the scripts. Each script includes an 'exit' command at the end of line?
July 23, 2010, 16:30 |
#6 | |
Saima
Do u know wat is batch command for CFX. my Mesh is in ICEM and every time it will be change , so i want to gice CFX commands starting with msh file. Do u know the way? If yes pls let me know. Regards, Quote:
[ANSYS Meshing] Problem with Icem Script | Krish | ANSYS Meshing & Geometry | 0 | October 18, 2011 12:10 |
[ICEM] SCRIPT File in ICEM CFD | Saima | ANSYS Meshing & Geometry | 0 | July 15, 2010 14:27 |
Using script file in ICEM CFD | Debabrata Mahapatra | CFX | 1 | October 22, 2007 17:45 |
script file to convert meshes from ICEM 4 to 10 | Seb | CFX | 0 | July 6, 2006 10:40 |
Icem script error in Workbench environment | mech80 | CFX | 11 | September 19, 2005 18:13 |
