how to identify transient simulation converged |
January 22, 2009, 07:59 |
I am just wondering how to know that my transition simulation has converged. actually, I am running a steady state simulation on airfoil case, and I found local convergence problem which, I guess, is caused by seperation bubble moving, i.e. it is actually a transient problem. So I start running transient simulation. what 's your comments on my case, and how do I know it is already converged (I have no experience on transient simulation).
tnanks, anyway littlelz |
January 22, 2009, 13:27 |
Re: how to identify transient simulation converged
when your lift and drag curve reaches to some periodic fluctuations.
January 22, 2009, 17:26 |
Assuming lift and drag are your key outputs, do a sensitivity check of mesh size, convergence tolerance and time step size (if transient) to assess the level of accuracy of your answer. Glenn Horrocks |
January 27, 2009, 05:26 |
Thanks for your reply.
That's what I am concerning; the timestep size in transient simulation. In my case, as I set the time step size very small, say 1e-8, it is converged quickly, 3-5 coeff loops. as I increase it, say 5e-7, it is very slow to reach convergence. What's that mean? how do I decide a proper tiemsetp size? Please advice |
January 27, 2009, 16:25 |
You find the correct timestep size by a sensitivity study. If you are getting 3-5 coeff loops at a timestep of 1e-8 then that is a good place to start as that is about the point where the transient solver usually works best - but check with a sensitivity analysis. Glenn Horrocks |
January 27, 2009, 18:13 |
oh, I see.
many thanks for your help. all the best |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 21:13 |
Starting a 3D URANS simulation from a converged 2D URANS simulation | Josh | Main CFD Forum | 2 | June 4, 2011 20:32 |
a transient simulation question | rystokes | CFX | 3 | June 3, 2009 07:44 |
Steady-state simulation to start a transient simulation | smagmon | CFX | 2 | May 18, 2009 03:59 |
Initialisation in transient simulation with ASIs | Phil D | Siemens | 7 | January 30, 2008 07:44 |
