January 26, 2009, 22:28 |
Cannot see residuals while solving
Ok so I did a clean install of vista 64 and now I have a weird problem. When I run the simulation, I can see the text information on the right but where the residuals are supposed to be, it's just gray. When I try to create a new monitor, I can't select any variables. However, when I stop the simulation, sometimes the residual graphics appears.
I have tried uninstalling CFX and reinstalling, but the problem persists. I haven`t tried a complete reinstallation of ANSYS yet. Could this be just some sort of problem with options setting? Any solution proposition are welcomed! |
January 27, 2009, 16:23 |
Re: Cannot see residuals while solving
Sounds like a graphics card issue. Have you checked your graphics card driver is up to date? Glenn Horrocks |
January 27, 2009, 20:27 |
Yes my drivers are up to date.
It could be a graphic problem, but I can't add a monitor either, so that's probably not it. |
January 29, 2009, 11:00 |
Ok so if I create a new simulation, everything works fine.
But when I try to run previous simulations, I run in the same problem. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
