Partial Inlet BC
Old   January 30, 2009, 02:17
Default Partial Inlet BC
YZ
I am setting BC with CEL, and my purpose is to allow liquid flows only through partial parts of the boundary with different mass rates. As I try to do it, I write this expression
step((0.02[m]-x)/1[m])*5+step((x-0.03[m])/1[m])*3
from the plot, it does what I want- some fluid flows with mass flow rate 5, some with 3, and some did not flow between the region 0.02~0.03. But it seems that CFX-pre does not allow this action since the message shows that mass flow rate should be defined to a single value.
the only idea in my head is to separate the boundary to more bounaries, but it cost a lot of time if I want to test many different set of parameters.
Wound anyone mind giving me a better idea?
Thx
Old   January 30, 2009, 09:58
Default Re: Partial Inlet BC
dace
Did you really tried xGlobal instead of x?
Old   January 30, 2009, 14:32
CycLone
Hi YZ,
The mass flow condition specifies the bulk flow rate [kg/s], not the local mass flux [kg/(m^2 s)]. To specify the mass flux locally, change the boundary condition to a velocity specified condition.
-CycLone
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
Inlet table in STAR-CD Sachin Siemens 1 March 26, 2008 10:22
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
