Interface Height Tracking
I have obtained a result of 2D free surface simulation with distinctive interface. Now in the post-processing, I want to obtain the value of height of some points located at the interface. I have reviewed the similar problem someone also had, but it's still no clear to get the wanted result (the average height is assessible) even though I am able to plot the curve of x and surface height. I'll appreciate any hint from you. Thanks a lot
Re: Interface Height Tracking
Generate a line object from the free surface contour and export the line object and you will get XYZ points which define the line. Glenn Horrocks |
Got it, thank you very much, Glenn It's pretty useful for me
