Calculation of Heat Transfer coefficient
Old   February 14, 2009, 08:50
Default Calculation of Heat Transfer coefficient
sachin
Hello i am doing a heat transfer analysis of fluid flowing through a sub-channel. Constant heat flux condition is given to the wall. Using Mass flow inlet and Pressure outlet.
In postprocessing of CFX there is a parameter "wall heat transfer coefficient". I want to know how is it being calculated in CFX. Actually i am calculating HTC by the following relation
q=h*(Ts-Tb) where,q=Heat flux, h=HTC, Ts=surface temp.,Tb=bulk temp. would u plz let me know about the parameter "wall HTC" and whether my way of calculating HTC is right? thank you.
Old   February 15, 2009, 17:52
Default Re: Calculation of Heat Transfer coefficient
Yes, you calculation is correct - although if you are using radiation modelling you may need to use just the convective wall heat transfer.
The calculation of h in CFX is described int he manual in the section describing the turbulence model at the wall (assuming you are using a turbulence model!). In short, CFX calculates a wall heat transfer, then estimates an ambient temperature and calculates h based on that. It does not model h directly.
Old   February 16, 2009, 02:24
sachin
thanks glenn.
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
calculate heat transfer coefficient in repeated geometry mullenc525 CFX 4 January 24, 2017 14:30
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
CFX doesn't continue calculation... mactech001 CFX 6 November 15, 2009 21:25
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
