March 10, 2009, 20:26 |
How simulate a fine screen
Hi friends,
i am new in the CFX modeling, i need modeling the flow through a fine screen with a flow area of 1 mm^2 spaced at 1 mm. i can't simulate because the density of elements is high (for a 100x100mmmm screen). Any know a trick to solve this problem? |
March 11, 2009, 21:29 |
Re: How simulate a fine screen
Use a 3D subdomain specified as a porous region. In CFX V12 you will be able to put a 2D surface with a resistance on it (I think as part of a interface). Glenn Horrocks |
March 11, 2009, 21:40 |
Thanks Glenn, what's is the diference between domain and subdomain ??
March 12, 2009, 16:25 |
Subdomains are usually only used to specify regions for either porous regions or initial conditions. Glenn Horrocks |
Display Modes | |
Car fire in an underground park - Simulate a temperature sensor | psc3 | Fluent UDF and Scheme Programming | 9 | June 9, 2014 06:16 |
divergence behaviour of interFoam solver for very fine mesh | purushotam85 | OpenFOAM Running, Solving & CFD | 0 | June 23, 2010 18:57 |
Modelling a screen in Fluent | Sushilkumar | FLUENT | 1 | April 15, 2009 12:03 |
What kind of computer is needed to simulate with OpenFoam | anita | OpenFOAM Running, Solving & CFD | 8 | February 21, 2008 11:25 |
how to converge the solution for fine mesh | kathiravan | Siemens | 5 | August 11, 2006 01:30 |
