heat resistance on solid-solid interface
Old   March 12, 2009, 05:32
Default heat resistance on solid-solid interface
Bela
Dear CFX users!
My problem is the following: there are two solid bodies which are connected with solid-solid interface. There is heat generation (W/m3) in either of the solid domains. The thermal conductivity of the solids is different. I should define an additional heat transfer coefficient (4000 W/m2K) because the thermal contact is not perfect between them. I don't know how to define this htc on the domain interface. I found that I could set up source, where the Flux coefficient is the htc, but I don't know the value of the Flux. Does anybody could help me?
Bela
Old   March 16, 2009, 14:31
Pratik Mehta
pratikmehta is on a distinguished road
Hi, could you please explain what do you mean by thermal contact is not proper . What exactly is your problem set-up .
pratikmehta is offline   Reply With Quote
Old   March 19, 2009, 03:55
andy2o is on a distinguished road
Thermal contact resistances are not supported in ANSYS CFX 11. There may be some way of representing such resistances with user defined code or CEL though - it might be worth contacting ANSYS directly for advice.
I was told by ANSYS that they will be supported (together with other surface physics enhancements) in CFX 12, but I haven't seen the Beta release of CFX 12 to check whether they actually made it to the actual product...
Best regards,
andy2o
andy2o is offline   Reply With Quote
Old   March 19, 2009, 08:53
Jack
rogbrito is an unknown quantity at this point
You can use Fluent for solving this problem.
Originally Posted by Bela
;92318
Dear CFX users!
Bela
rogbrito is offline   Reply With Quote
Old   March 19, 2009, 11:11
Pratik Mehta
Is your problem a natural convection or forced convection , all I can for now think of is that , you can have model the improper contact between the two solids as a porous media ( separate porous domain) , this porous domain should be having all the flow resistances in 3 directions.
I hope this helps
cheers
Pratik
Old   March 19, 2009, 17:43
Pratik,
When two bodies are held together, the (perhaps large, or perhaps microscopic) roughness of the surfaces of the bodies means that they do not come into uniform perfect contact. There will be small gaps between them (often filled with air). Therefore for heat to flow from one body to another it has to cross this small gap by conduction, small scale convection, or radiation. This gives rise to thermal resistance.
Because the gap is so small, you do not want to mesh it or model it as a 3-d feature. Instead, it is often modelled as a thermal resistance at a surface. Unfortunately CFX does not yet easily support this. This is what Bela was asking about.
I hope it makes sense now.
Best regards,
andy2o
Old   March 20, 2009, 02:28
Pratik Mehta
Hi Andy ,
ok, now it is clear abt Bela`s query , you are right CFX till now have no such feature till now
thanks andy
best regards
pratik
Old   October 25, 2022, 15:57
Ubade Kemerli
ubadekemerli is on a distinguished road
Hi Bela,
I use fluent, and I don't know if you can do it at CFX, but what I do in fluent is that I add a wall thickness and define a material for that wall thickness. By doing that, you can have the same thermal resistance by defining the thickness and thermal conductivity of the material properly. Hope that helps.
ubadekemerli is offline   Reply With Quote
Old   October 25, 2022, 16:02
Opaque will become famous soon enough
- Open the solid-solid domain interface
- Go to the Additional Interface Models tab
- Select Heat Transfer/Interface Model option = Thin Material
- Select Material name
- Set material thickness.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Opaque is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 11:05
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
