March 18, 2009, 20:30 |
Multiple Moving Meshes Animation
Tristan Burton
Rep Power: 17 |
I have a moving mesh simulation that is made up of a sequence of meshes. I run them one after the other (using separate .def files) in order to study a piston-cylinder problem so that I don't end up with really small cells during compression or really large cells during expansion. Does anyone know how I can combine the different meshes and their associated transient result files into a single animation?
Thanks, Tristan |
March 19, 2009, 03:54 |
Matthias Voß
Rep Power: 20 |
hey!
you could save the single frames for each .res file and simply copypaste them in one folder and make an new animation out of them.Should be possible with ... maybe...Irfanview. If there are many .res-files you should think about batchprocessing via sessionfiles. neewbie |
March 19, 2009, 12:45 |
Tristan Burton
Rep Power: 17 |
I only have 3 .res files but each of them has around 10 .trn files so I was hoping CFX Post would allow me to bring them all in at once and create one animation. Apparently that's not possible?
Thanks, Tristan |
March 19, 2009, 19:14 |
Rep Power: 143 |
Yes, it is possible. You can use the CFX-Post scripting to get it to load the 3 results files sequentially. Don't use the animation gizmo in CFX, use a script file to load a timestep, write a frame, load the next timestep, write a frame, load the next res file... etc. To get you started in CFX-Post session files, record a session doing a frame or two of the sequence and edit it from there. Glenn Horrocks |
Multiple .res files in animation | Gloria Gaynor | CFX | 5 | April 6, 2009 19:36 |
Animation of multiple cgns files | John Smith | Main CFD Forum | 0 | February 19, 2008 14:57 |
VOF and moving meshes | Dave | FLUENT | 0 | May 7, 2007 01:54 |
Moving meshes | charlotte | Main CFD Forum | 5 | September 19, 2006 07:52 |
Moving meshes | Kraev Stanislaw | Main CFD Forum | 2 | April 11, 2003 13:09 |
