January 26, 2010, 02:06 |
Set the inflow condition from the outflow
Hi, I want to get the outflow velocity value and set them as the inlet velocity. For example, the distance between the inlet and outlet is 10 meters. I will set U_inlet(x,y,z,t) = U_outlet(x+10,y,z,t). How to make it? I have read the User Fortran. But I do not know how to get a obtain a velocity from point(x,y,z). Can you help me? Thank you!
January 26, 2010, 16:21 |
Rep Power: 143 |
No, this is not the way to do it. You will need to use a periodic boundary condition. V12 has a lot of extra features for this type of boundary to do exactly what you are trying to do.
January 26, 2010, 20:36 |
Hi ghorrocks, thank you. I find that in V12 they are rotational periodic condition such as turbo. But actually I want to rescale the outflow velocity and reintroduce it to the inlet. I am afraid that 's not regular periodic interface operation. So is there any way to realize it?
January 26, 2010, 20:47 |
Rep Power: 143 |
Can you explain what you are trying to do? What you are describing does not sounds physically possible as it does not conserve mass.
January 26, 2010, 21:22 |
I want to do a transient simulation. The inflow velocity at the inlet is computed from the outflow velocity at the outlet on every time step. For example, U_inlet(x,y,z,t)=2*U_outlet(x,y,z,t). This is just an example. Actually the transformation is a little complex and not just multiply 2. Is this clear?
How to set outflow boundary condition | bian222 | STAR-CCM+ | 0 | January 24, 2010 00:16 |
Outflow boundary condition for a boussinesq fluid | lin | OpenFOAM Running, Solving & CFD | 19 | July 31, 2009 08:50 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
