Transient run error
Old   April 25, 2009, 12:27
Smile Transient run error
Jack B.
Turbulent is on a distinguished road
I've a certain problem while runing transient analysis at CFX.
After a number of timesteps (for example 250) I get the following message at the out file. I would like to mention that the solution is behaving good for the solved timesteps (timesteps is small enough and convergence is adequate for each timestep).
Does anyone has an idea ??
Thanks,
Jack
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| create_indextable: stored index is wrong: missing start tag |
| Message: |
| iif_open: unable to read the stored index, attempting to rebuild |
| it |
| Message: |
| recreate_indextable: Bad file: expected dataset, index or end, go- |
| t "024" at byte 3770448
| Message: |
| iocnt: open the primary file failed |
| Message: |
| OpenFile: open primary file failed |
| Writing crash recovery file |
| Message: |
| Stopped in routine OpenFile |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
Turbulent is offline   Reply With Quote
Old   April 26, 2009, 18:56
Weird error. No idea what is causing that but I would check:
Are you sure you are not running out of disk space? CFX writes some temporary files which can get quite large so you need more space than just the res and def files.
Are you sure your permissions are set correctly?
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 172 April 13, 2023 00:42
Error within a batch run Jia Li CFX 7 July 29, 2010 18:54
Building error of 15dev for OpenSUSE 111 on AMD64 machine waynezw0618 OpenFOAM Installation 1 February 18, 2009 10:12
Installation problem with GCC Norma McKee (Mckee) OpenFOAM Installation 10 March 4, 2007 07:09
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
