Please help, Error: No FSIN boundary conditions defined in the model. |
March 27, 2009, 14:38 |
Faraaz
Rep Power: 17 |
I am trying to run ansys cfx in a script file (or batch file) at a command line. This is a FSI problem. The line i used to run cfx and ansys is as follows: cfx5solve -double -def flagwithoutpoleU8.def -ansys-input FSIU8.inp this line launches both ANSYS and CFX Solvers, starting from the definition file flagwithoutpoleU8.def and using the ANSYS input file FSIU8.inp. I got that line from the Ansys cfx help manual. But for some reason I am getting the error message as shows below: ADDITIONAL SYNCHRONIZATION FOR CFX: SECOND SYNCHRONIZATION POINT OF MASTER CODE: GET INTERFACE MESHES, INITAIL VALUES, and RESTART LOADS *** ERROR *** CP = 0.140 TIME= 19:11:26 No FSIN boundary conditions defined in the model. *** ERROR *** CP = 0.140 TIME= 19:11:26 No FSIN boundary conditions defined in the model. I don't understand why am getting this error message. The FSIN boundary condition was properly defined in cfxpre with the Ansys input file filepath correctly chosen. The .def file was then written. However when run i am getting the error message above. Can anybody please help me. I really need to figure this out urgently. Thanks cfxuser1 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
Water vapour condensation in CFX-5.7.1 | hdj | CFX | 1 | November 27, 2005 07:15 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
