July 31, 2008, 04:13 |
CFX best practice for external flows
Does any know of some best practice guides for external flow (flow over aircraft, 2-D aerofoils and external stores) using CFX? For most of my work I conduct grid independence tests , but I find runs become independent with millions of elements. But was gauging such issues as fluid domian size, I have a good idea what is best for me, but would be interested in what others use. The same goes for inflation layer details - I've not really got a full sense on using yplus and stick with first-layer thinkness instead. And anything else I missed. Thanks. |
August 3, 2008, 18:46 |
Re: CFX best practice for external flows
That's right - external aircraft aerodynamics will require millions of elements. If you are adding external stores then more like tens or hundreds of millions. That's CFD for you, if you want accurate results for this type of modelling you must get a computer capable of running simulations of this magnitude. Glenn Horrocks |
August 3, 2008, 20:17 |
Use Hexa mesh, then you will have less computational effort and less time of cpu.
August 4, 2008, 02:32 |
Glenn, I'm running with very large element amounts. Odd how in many academic papers runs are made with less than 1 million, however they always omit the details.
With all the options in CFX, of which I don't use many as I don't have the necessary numbers, is there a guide as to what are best for external flow? |
August 4, 2008, 21:58 |
External aerodynamics with less than 1M elements is either inviscid or viscous and hopelessly inaccurate. As to what options to choose - that depends on what you want to do. They would not pay my salary if there was a simple answer to that question. Glenn Horrocks |
May 3, 2009, 22:44 |
Shawn Givler
Rep Power: 16 |
siw
For bluff bodies and streamlined vehicle aerodynamics my rules of thumb are 2 vehicle widths to each side, 6-10 vehicle lengths downstream, and 2-4 vehicle lengths upstream. Shawn |
Display Modes | |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Import Fan 3D Model - Workbench or CFX? | Stewart Long | CFX | 2 | October 28, 2008 04:05 |
MFX: weired force transfer from cfx to ansys | zyf | CFX | 3 | October 7, 2006 03:08 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 11:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
