May 6, 2009, 21:53 |
Jumps In hybrid Mesh
Rep Power: 16 |
Hello Guys,
I have been testing out the simple TUBE hybrid hexa,tetra hybrid meshing tutorial in ICEM CFD. I do a quick run in ansys CFX , and at the interfaces there appears to be a pressure jump at each mesh interface. The velocities seem fine though (although the boundaries are better with the hexa mesh) Does anyone have experience with hybrid meshes? are they safe to use for more complex cases ? |
May 7, 2009, 19:00 |
Rep Power: 143 |
Hybrid meshes are fine. You can get some apparent jumps at interfaces when the mesh is not fine enough. Also I assume you have all the pitch ratio stuff turned off - that can cause these effects. Glenn Horrocks |
May 7, 2009, 21:53 |
Rep Power: 16 |
Do you mean pitch ratio of the hexa mesh at the interface ? So the ratio there should be 1 ?
May 7, 2009, 23:02 |
Rep Power: 16 |
May 8, 2009, 04:35 |
Roland Rakos
Rep Power: 17 |
I think that if there is pressure jump at interface than hexa and tetra mesh don’t connect exactly at the interface. The nodes of interface 1 have to fit to the nodes at the interface 2. (1:1 connect) If the nodes don’t fit to each other than there is an interpolation at the interface, this can cause some inexactness. (The size of the inexactness = How many cells do connect to one cell at the interfaces?). Roland |
May 10, 2009, 21:43 |
Rep Power: 143 |
Pitch ratio is used in turbo machinery so blade rows with different numbers of blades can be modelled using periodic boundaries. That is a blade row with 100 blades can be connected to a row with 149 blades, where you are only modelling a single blade of each row. You use the pitch ratio to scale the flow across the interface to keep the relationship between the rows correct. If you have pressure jumps at an interface then something is wrong. Is your solution properly converged? Is you mesh quality adequate? Have you got mesh size jumps at the interface? Glenn Horrocks |
zonal hybrid mesh | Maolin Tu | Main CFD Forum | 5 | May 16, 2020 12:19 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Commercial meshers] fluentMeshToFoam with Hybrid Mesh | -mAx- | OpenFOAM Meshing & Mesh Conversion | 2 | May 7, 2009 01:43 |
Hybrid Mesh | Marc | FLUENT | 4 | July 18, 2007 20:38 |
hybrid mesh around a stator | Michele Cagna | FLUENT | 2 | October 25, 2000 09:12 |
