empty fluid domain
2 Attachment(s)
hi |
You need to extract the fluid volume from inside the object. There are several tools to do this in Workbench. You will also need to put an extended inlet and outlet on the device to get accurate results. Glenn Horrocks |
thank u
internal surfaces of geometry are piecemeal.what tools are usefull for this problem??? |
This is a very basic operation in Workbench - do some of the Workbench tutorials and it should be obvious. There are some examples on using CAD imported geometry and these are good ones for you to do. Glenn Horrocks |
thanks dear
