June 3, 2009, 03:54 |
Nasa profiles
Hi,all
NASA WIND PROFILES, WHICH TYPE OF CODE BETTER AIRFOILS
sivaramakrihnaiah |
June 3, 2009, 07:47 |
Rep Power: 143 |
Can you state your question more clearly? I have no idea what you are asking for. Glenn Horrocks |
June 4, 2009, 01:13 |
Nasa airfoil
HI,
Actually i am analyzing wind turbine rotor,in that i want select better blade airfoils ,i have lot of airfoils data,in that which is the better one, which type of series (ex:1,2,3,4,5,6,7,8 series ).
sivaramakrihnaiah |
June 4, 2009, 13:00 |
Paulo Alexandre Costa Rocha
Rep Power: 17 |
Hi Sivaramakrihnaia,
We've been studying wind turbine blades for some years (three), and there are not all the types that you asked. In fact, the profiles are NACA, and the 5 digit series is one that you could start working. Hope that helps, Best Regards, Paulo Rocha |
June 5, 2009, 15:42 |
Rep Power: 17 |
Hi again,
Sorry for the information. I would like to say 6-digit series. What methodology will you use to design the blade (chord and pitch angle?) Best Regards, Paulo Rocha |
June 6, 2009, 00:22 |
Nasa 6 series
diameter of rotor:2m, chord size:0.3m number of blades:3 is it any profiles is there. if dont mind your mail ID should forward me,i will send mail. Thankyou very much.
sivaramakrihnaiah |
June 6, 2009, 23:33 |
Rep Power: 17 |
My e-mail address is paulo {at} posmec [dot] ufc [dot] br What do you plan to do with the simulation. Will you build the turbine ? Regards, Paulo |
NASA Format | Stone | CFX | 3 | August 11, 2021 02:16 |
Laminar wing profiles and drag | gregorv | OpenFOAM Running, Solving & CFD | 4 | December 4, 2007 13:25 |
Gas flow profiles in mixing tank | srinivas | FLUENT | 0 | November 8, 2006 04:52 |
Variable Names in Profiles | Jonas Larsson | FLUENT | 0 | April 18, 2001 06:59 |
component flow direction fieldnames for boundary profiles required. | Ricky Wong | FLUENT | 1 | May 12, 2000 10:36 |
