Constant temperature results
Old   June 12, 2009, 10:39
Default Constant temperature results
lost.identity is on a distinguished road
I've just run a simulation of a converging-diverging nozzle using CFX. I pretty much left the Solver Control options as default (i.e. High resolution advection scheme, Autotimescale, Continuity Equation class.)
The problem is in my results the temperature is a constant value. However I can see that the static pressures and the velocities are changing in the nozzle, and they look physical.
Does anyone have any ideas why the temperature is constant? (it should physically change quite a bit in my nozzle)
One thing I need to mention is that the Mach numbers upstream of the nozzle is very low (about 0.03). How does CFX deal with such low Mach numbers? And the maximum Mach number in the throat reaches 1.3.
lost.identity is offline   Reply With Quote
Old   June 12, 2009, 10:59
ckleanth's Avatar
George
ckleanth is on a distinguished road
for high speed flows you need to use total energy heat transfer model to take into account the energy change due to kinetic energy effects
havent done much on high speed flows
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 12, 2009, 11:44
Edit: found it.
Old   June 12, 2009, 12:41
When I select Total Energy heat transfer model it's gives the following error.
There must be an object of type HEAT TRANSFER in the object/FLOW/DOMAINefault Domain/BOUNDARY:inlet/BOUNDARY CONDITIONS but it does not exist
I can't see any option of selecting HEAT TRANSFER in the inlet BCs.
Old   June 12, 2009, 16:04
ckleanth's Avatar
George
not possible; if you selected a heat transfer model you need to specify a temperature in the inlets
possible out of memory so gui is playing up or your installation is corrupt
Top 4 tips
Chemical properties that are used in Fluent kimej FLUENT 4 August 19, 2011 11:29
LES of highly heated pipe flow - incorrect results MichalH FLUENT 3 June 3, 2009 05:00
Exporting temperature results fro fluent to Ansys vinay kulkarni FLUENT 1 February 21, 2007 03:31
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Temperature discontinuity with Species Transport Dominique FLUENT 0 August 31, 2004 20:27
