Convergence of CFX field in FSI analysis
Old   June 28, 2009, 12:37
Default Convergence of CFX field in FSI analysis
chris
nasdak is on a distinguished road
Hello friends
I do the fluid-structure interaction of the aortic valve and blood. I managed the negative element volume and analysis go ahead. I have only one problem. During every coupled interaction I have no convergence for CFX filed.
*** ANSYS BINARY FILE STATISTICS
BUFFER SIZE USED= 16384
122.938 MB WRITTEN ON ELEMENT SAVED DATA FILE: ANSYS.esav
162.000 MB WRITTEN ON ASSEMBLED MATRIX FILE: ANSYS.full
59.125 MB WRITTEN ON RESULTS FILE: ANSYS.rst
//the end of the structure calaculation - everything is fine.
FOURTH SYNCHRONIZATION POINT OF MASTER CODE:
LOAD TRANSFER AT THE END OF SOLUTION
FIFTH SYNCHRONIZATION POINT OF MASTER CODE:
GET SLAVES LOCAL CONVERGENCE
FIELD SOLUTION CONVERGENCE
CONVERGENCE OF FIELD SOLVER: ANSYS. . . . . TRUE
CONVERGENCE OF FIELD SOLVER: CFX. . . . . FALSE
//not converged ??
SURFACE LOAD TRANSFER CONVERGENCE
CONVERGENCE FOR FIELD 2 ACROSS INTERFACE 0
UX DISP CONVERGENCE. . . . . . 0.70735
UY DISP CONVERGENCE. . . . . . 0.72570
UZ DISP CONVERGENCE. . . . . . 0.70866
CONVERGENCE FOR FIELD 1 ACROSS INTERFACE 1
FX FORCE CONVERGENCE. . . . . 0.68833
FY FORCE CONVERGENCE. . . . . 0.69597
FZ FORCE CONVERGENCE. . . . . 0.68933
SERVE SLAVES THE GLOBAL CONVERGENCE
1
Have you ever seen similar problem ?? Or may you have same idaes what's wrong??
regards
Chris
nasdak is offline   Reply With Quote
Old   June 28, 2009, 19:16
FSI adds another dimension of things to check over a normal static CFD simulation. Have you checked it converges OK without FSI with some geometries typical of what you will get in the simulation? Have you checked the FSI motion updates are small enough that you are resolving the motion properly?
Old   June 29, 2009, 01:17
chris
Glenn
I've checked it but only for the first state of geometry, and the fluid converged. During the simulation I had a problem with negative volume element then I decrease the substep. Now the deformation is close to 0.1 mm and I think the FSI motion is small enough. May I should decrease the time of the substep again ? I must admit that I have a quite poor mesh.
cfx, convergence, fsi
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
FSI convergence problem YY CFX 0 April 13, 2008 10:54
FSI using Ansys LS-Dyna and CFX YY CFX 2 April 9, 2008 06:40
CFX 2D ANALYSIS BOUNDARY CONDITION fat bug CFX 1 February 19, 2008 16:22
FSI using cfx and ansys vs ls dyna or dytran HAYATE CFX 1 September 21, 2007 15:11
