WATER CLOSET DRAINAGE
Old   September 20, 2003, 03:03
Default WATER CLOSET DRAINAGE
VEDAT
HI HAS CFX AN ABILITY TO SIMULATE THE WATER MOVEMENTS INSIDE THE WATER CLOSET TO TEST ITS FUNCTIONALITY ??(DRAINAGE OR WATER CONSUMPTION)
Old   September 22, 2003, 11:28
Default Re: WATER CLOSET DRAINAGE
BAK_FLOW
Yes,
the flow in a sanitary system is an open channel flow and requires the resolution of the interface between the water and the air. This is often called free-surface flow. Further, in such equipment one may be interested in the movement of another phase which can be modeled as either an Eulerian fluid or as a Lagrangin particle in CFX-5.6
Regards,
BAK_FLOW
Old   July 15, 2009, 13:56
mechovator
mechovator is on a distinguished road
Hello dear
I just saw your problem and learned that you got its solution. I have just started my MS and am working in the same field. It would be very nice of you if you could please help me. Feel free to contact me on
mechovator@yahoo.com
With best regards
Mechovator
mechovator is offline   Reply With Quote
Old   July 15, 2009, 16:31
Rui
Rui's Avatar
Rui Igreja
Rui is on a distinguished road
Have a look here:
Decreasing Water Consumption in Toilets. Optimization of a sanitary discharge valve using ANSYS CFX: http://www.ansys.com/industries/cons...oiletvalve.htm
Optimization of a sanitary discharge valve using a numerical approach: http://www.wseas.us/e-library/confer...rs/498-704.pdf
Numerical and experimental optimisation of a gravity driven free-surface flow: http://www2.dem.uc.pt/antonio.gameir...SEAS_paper.pdf
Rui
Rui is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
WATER CLOSET DRAINAGE VEDAT Main CFD Forum 4 September 22, 2003 08:49
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
