August 13, 2009, 02:52 |
Mesh motion on inlet (2-way FSI)
Lance
Rep Power: 22 |
Im doing coupled 2-way FSI on basically a long pipe with both a fluid and a solid part. The solid is free to move in radial direction and has a zero displacement boundary condition in axial direction on the in and outlet. The fluid part on the other side, has mesh motion set to "Unspecified" on the in and outlet, to let it follow the solid parts motion in radial direction. I get a warning saying: "Mesh motion is specified on the boundary 'inlet'. This is valid for motion that is tangential to the boundary but solution errors will occur if motion is normal to the boundary". Well, I only want the inlet to move in radial direction, but after a couple of 1000 timesteps the fluid part starts to move in axial direction and the solution diverges. Is there a way to set an axial zero displacement on the fluid part as well when doing coupled 2-way FSI? Lance |
August 13, 2009, 05:21 |
2-way fsi
dss
Hi:
You can build model (structure model)in ansys, fluid model is built in cfx. THen use the mesh motion. |
August 13, 2009, 05:31 |
Lance
Rep Power: 22 |
Help with Mesh motion preview | Mustafa Ayad | FLUENT | 2 | January 20, 2009 22:40 |
Discrete Values for Mesh Motion | UnderwaterAlex | CFX | 2 | February 21, 2008 18:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
How to control the Inlet block mesh in turbogrid | Mickel | CFX | 0 | June 21, 2006 20:21 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
