Temperature dependent thermal property in CFX |
August 21, 2009, 14:14 |
Subhadeep
Hi
Trying to define a material in CFX pre with temperature dependent expression This is what I entered : 2.9544 + 0.02*T [W m^-1 K^-1] While running gives me error saying : Error processing expression 'Thermal Conductivity'. Error at position 17. Units [W m^-1 K^-1] are associated with an expression that is not dimensionless. What should the correct expression be? Should I take out [W m^-1 K^-1] ? Thanks .... |
August 21, 2009, 14:56 |
The problem is that T has a units associated with it. What you need to do is make sure the final result ends with a [W m^-1 K^-1]. So we would have to change it to:
2.9544 [W m^-1 K^-1] + 0.02 [W m^-1 K^-2] * T Notice the Kelvin unit on T will cancel the one associated with the 0.02 providing the correct units. Let me know if you need further explaination. |
August 21, 2009, 15:07 |
Thanks
Subhadeep
That helped ...
After reading the messages I thought on similar lines but used it like this and that still gave me an error : 2.9544 [W m^-1 K^-1] + 0.02*T [W m^-1 K^-2] |
August 21, 2009, 15:29 |
Needs to be exactly as I have it. Again the units of [W m^-1 K^-2] must be associated with 0.02 and not as you have it where CFX is trying to associate T with [W m^-1 K^-2] when it already has units of [K].
August 22, 2009, 20:21 |
#5 | |
Jack
Hi Sir,
let me explaining ! For example, for the heat flux boundary condition, you have to build a variable called Fluxoa, like this (where t is time in [s], and Fluxoa is a heat flux in [W m^-2]: Fluxoa (B*(19453.29701*(t/A)^3.07678)/(4.73947^3.07678+(t/A)^3.07678)) A 1.0 [s] B 1.0 [W m^-2] So, the Fluxoa variable will have the [W m^-2] final heat flux unit ! with kind regards, Rogerio . Quote:
March 22, 2012, 01:52 |
will this be also valid if i were to define a temperature dependent body load please?
Thank you for your kind attention. Kind regards, mactech001 Currently using: ANSYS v13 |
units |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
Problems in CFX 5.5.1 | Sulviyanti | CFX | 6 | February 7, 2003 16:46 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
