how to export data from CFX-post
Old   September 11, 2009, 08:18
Smile how to export data from CFX-post
Rachel
Rachel_09 is on a distinguished road
I have a question about how to export data from cfx-post.
I already have *. res file. Then I have the coordinate of the points set (x, y z, in *.txt file). I would like to have the velocity and pressure information at these points. How should I do.
I tried to make a *csv file with the point coordinate file, then import into cfx-post. but It does not work. It says "Error Invalid contents of file for importing data, or type can not be determined".
So what's the problem?
Do anyone have other way to get the flow information of the coordintes?
Any comments will be appreciated.
have a nice day!
Rachel_09 is offline   Reply With Quote
Old   September 12, 2009, 08:27
Record a session file in CFD-Post where you make a point using XYZ coordinates. Then edit the file to create all of your points and play the session file.
Old   September 14, 2009, 09:51
Smile I have difficult in reading the point coordinates in Session file
Rachel
When I play a sessin file to read the point coordinates from the *.txt file. I got the following error message. This is the first time I use session file. What do you think is the reason?
ERROR
CCL parser failed with message:
invalid parameter name: must be non-empty.
The session file is as follows:
# Session file started: 2009/09/10 16:57:39
# CFX-11.0 build 2007.08.09-23.01
# To avoid unnecessary file pre-processing and modifications, include
# COMMAND FILE at the top of your session file.
# If it is not included, the file is assumed to be older and will be
# modified for backward compatibility.
COMMAND FILE:
CFX Post Version = 11.0
END
$filename="Ployline1.txt"
open(MYDATA, "qPlane5a1.txt") or die("Error: cannot open file 'qPlane5a1.txt'\n");
my @lines = <MYDATA>;
chomp @lines;
print "@lines";
close MYDATA;
# Session file stopped: 2009/09/10 16:58:25
Please indicate what is the problem and what I should do?
many thanks
Old   October 31, 2012, 19:25
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
Hello all,
I am also trying to achieve something similar and extract data into CFD post. I created a point in space using x,y,z coordinates in FLUENT and the data for each time step was written into this however, it becomes a .out format rather than .txt or .csv.
Please comment or provide some guidance on the best way to extract unsteady data for time-dependent plots in CFD Post. Thanks everyone.
Last edited by Crank-Shaft; November 1, 2012 at 16:56. Reason: Posted into the wrong thread
Crank-Shaft is offline   Reply With Quote
Old   October 16, 2017, 14:46
Katja N.
Katja is on a distinguished road
Originally Posted by Rachel_09 View Post
ERROR
For me, I have found that the error was due to forgetting to put "!" before the $path in the following sample code
! $outfile = "output.txt";
! $path = "C:/home/katja/SimulationData/";
! open(OUTPUT,">>$path$outfile");
! $time = getValue( "DATA READER", "Current Timevalue");
! print OUTPUT "$time\n";
! close OUTPUT;
Katja is offline   Reply With Quote
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
Export AreaAve data at each time step in CFX Post Kumar CFX 2 August 22, 2007 12:32
(CFX POST) Rotational Speed ARJUN CFX 9 July 13, 2006 20:38
Variable export from CFX post Ram CFX 2 October 20, 2005 06:00
creating expresions in cfx build or cfx post alex CFX 1 August 22, 2002 13:01
