ERROR IN CFX-PRE ( RESULT FILE) someone please help? |
December 1, 2020, 23:07 |
eunchong hwang
Rep Power: 5 |
Whenever i try to run solution, i keep receiving a message says, " The ANSYS CFX solver exited with return code 1. No results file has been created." and also another one says," Update failed for the Solution component in CFX. The solver failed with a non-zero exit code of : 2,"
can someone tells what the problem is? here's file that i'm working on https://drive.google.com/file/d/1cB8...ew?usp=sharing |
December 2, 2020, 00:30 |
Rep Power: 143 |
Those error messages are from workbench and are not very useful as they do not tell you much. You have to look at the output file (in solver manager) as that has the detailed error messages.
December 2, 2020, 01:37 |
eunchong hwang
Rep Power: 5 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
