ERROR #001100279 NAME_MOD: Error finding variable "PRES"
Old   September 21, 2009, 08:50
Default ERROR #001100279 NAME_MOD: Error finding variable "PRES"
peterputer1 is on a distinguished road
Hej,
if I run my definition file i get the following error msg in the solver.
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
In my simulation i defined a new material, after adding it to the domain i get the error msg, without the computation runs.
I set a new solid, and took an expression for density, specific heat and conductivity.
I defined them in a csv table and just wrote in "Material properties"
Material.Density(T,p) as an expression.
I m not sure if i did it correctly, so hopefully you can help me
Regards
peterputer1 is offline   Reply With Quote
Old   September 21, 2009, 18:32
I don't think you can have a solid density a function of pressure. The pressure variable does not exist in solid regions. Or is the solid for particle tracking?
Old   September 22, 2009, 05:20
Hej,
thanks for the answer. My bad, for sure i cant set a pressure value for a solid :/
Thx a lot
Regards
Instalation on ubuntu 710 basilwatson OpenFOAM Installation 17 March 16, 2012 20:16
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 08:19
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
