September 21, 2009, 22:05 |
particle extraction
Dane
Rep Power: 16 |
Hi there,
I'm modelling a cylinder rotating and emitting dust particles tangentially at the bottom surface. I have this set up fine and it seems to be working well, when on it’s own. But now I need to add in an extraction system. Is it possible to model this as some sort of hose type object inside my flow domain? This is what I have been trying to do, but what do I set the boundary conditions as? It seems strange to have an inlet inside another inlet and doing this doesn’t work I have also tried using an opening at this inlet of the dust collection devise. Also, the modelling of what’s causing the extraction of dust is not important as measurements of the velocity of air going through the collection the device have been measured. Is the correct way to model this to add in some sort of momentum source at the face of the dust collection device? I have attached a picture of my model (symmetry zx plane @ min y) Cheers. [IMG]file://///engcad4/dwh47$/My%20Documents/Research/With%20extraction/domain.png[/IMG] |
September 22, 2009, 07:10 |
Rep Power: 143 |
Before you consider how to model it you should think carefully about exactly how the flow works, so you can define it properly.
It seems you have 3 factors you need to define: 1) The flow in the room 2) The flow in the extraction system 3) The dust generation Assuming this thing operates in a normal ventilated room then the surrounding air flow is defined by the AC system or open windows or whatever makes the room air move. You should then incorporate these in your model to get the room air motion right. For point 2 you need to consider how the extraction system works. Is it a pump with a filter? Then you should get the pump curve and filter characteristics. This will help you define the operating point of the extraction system. to implement this in your model it could be either a defined pressure or a defined flow rate, what ever matches the pump characteristics best. You could even put the pump curve in as a boundary condition if you are game. You mention you know the extraction velocity, so a specified velocity outlet sounds good. For point 3 you have to define the size, amount, location and initial velocity of the particles. You suggest this is already known. There should be no need in this model to use momentum sources. Simple boundaries should work fine. |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Particle track files | Sankalp | CFX | 1 | August 25, 2004 23:25 |
the separated particle temperature in cyclone | mkuswadi | FLUENT | 0 | December 17, 2003 08:25 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 03:56 |
Particle Trajectory calculation when particle hit | yueroo | FLUENT | 2 | February 28, 2001 04:26 |
