October 23, 2009, 13:35 |
CEL for Interface Curvature
Miguel Baritto
I'm working in a two phase flow simulation and I need to define a CEL function depends on interface curvature. I have looked for this variable in CFX-Pre but I haven't found it, so I think I must to define it. I know interface curvature is define by divergence of normal vector pointing from primary fluid to secondary fluid, but I don't know if is possible (and how) to write this expression. Thanks in advance Miguel Baritto |
October 24, 2009, 07:02 |
Rep Power: 143 |
Is it to be calculated during the solution or for post-processing? It should be much easier to do it in post-processing.
October 24, 2009, 13:38 |
Miguel Baritto
Hi Glenn,
I'm using two resistance model for heat transfer between liquid and vapour in stratified two phase flow, so I need to specify interfacial heat transfer coefficient. I need this CEL expression: h=ho*K/Ko, where h is HTC, ho is a referencia value for HTC, K is interface curvature and Ko is a reference value for curvature. I don't know how (if is possible) write K in CEL. Thanks Miguel |
Angle variable under CEL. | Gloria Gaynor | CFX | 11 | November 26, 2012 07:29 |
junction box routine and CEL function | bornspur | CFX | 2 | February 3, 2009 03:24 |
Rotate node via cel | Elian81 | CFX | 2 | September 25, 2007 06:31 |
CEL help! | CC | CFX | 3 | September 24, 2007 09:56 |
how to load a cel file? | ioana | CFX | 11 | June 24, 2004 20:42 |
