December 7, 2009, 09:12 |
Interface troubles
I'm trying to modeling a rotating machine. So I've to use an fluid fluid interface for the rotor stator connection, I'm using a GGI connection. But I've got somme troubles when I'm looking at the vorticity. As you can see on the image, the vorticity is not well transmit at the interface. Have you already seen this problem ? vorticity_pb.jpg Last edited by Samu; December 7, 2009 at 11:41. |
December 7, 2009, 18:14 |
Rep Power: 143 |
Vorticity is not "transmitted" at the interface. mass, momentum and energy is. The vorticity is calculated from the velocity field and I suspect the vorticity calculation is not exact adjacent to the boundary.
If you look at the pressure, velocity or temperature fields they should be continuous as they are "transmitted" at GGIs. |
December 8, 2009, 03:38 |
Ok
thanks a lot, I have look for the velocity and the pressure flieds and the continuity is good at the interface. |
Display Modes | |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
